Closed Thread
Old 12-08-2023, 02:46 PM
jeff71 jeff71 is offline
I don’t have any data other than “looking X guessing”. I would bet the stock LS7 Camaro Z/28 Tri Y headers will make more power. The GM Powertrain team did a lot of work on those Z/28
Manifolds to get over 505 HP stock.
I have made over 900 HP with the Holley exhaust manifolds on a blower motors.
Both are good. The Holley’s fit the “look” of the engine bay better.
Mark
On season 1 episode 15 of Engine Masters they tested the Holley manifold against a mid and full length on a LS.
But for those that don’t have the capability of watching.
The Following 3 Users Say Thank You to jeff71 For This Useful Post:
camcojb (12-08-2023), colorado80439 (12-18-2023), fleet (12-08-2023)
  #202
Old 12-09-2023, 10:28 AM
dhutton dhutton is offline
I have made over 800 HP with the Holley exhaust manifolds on a blower motors.
Mark
Thanks. I use those tri-y LS and LT manifolds on all the junk I build . I find them on eBay for a couple of hundred dollars. Great value but they are a little ugly.
The Following 2 Users Say Thank You to dhutton For This Useful Post:
214Chevy (12-10-2023), camcojb (12-09-2023)
  #203
Old 12-13-2023, 03:40 AM
Stielow's Avatar
Stielow Stielow is offline
Default Hobbs Camaro (Old Drag Car)
What I learned on the Gen 5 Camaro Z/28 program is the LS7 works better if you keep the oil cool. This Earls oil cooler maybe a tad too big put I had it on the shelf. Im also using an Innovative Eng thermostat to regulate the temp. For a cruiser I chose the 210F thermostat.
You really want to get the oil temp up to 212F to help get the water out of the oil when you are just cruising around.
It required a little rework of of the header panel support.
Stielow Engineering
The Following 7 Users Say Thank You to Stielow For This Useful Post:
BonzoHansen (12-17-2023), camcojb (12-13-2023), dhutton (12-13-2023), EVIL SS (12-13-2023), fleet (12-18-2023), Ketzer (12-13-2023), srode1 (12-19-2023)
  #204
Old 12-13-2023, 12:06 PM
syborg tt's Avatar
Hi Mark,
Quick Question.
I am so torn with painting my Radiator and AC Condenser as I feel the paint always flakes off. Do you have any suggestions as what to use.
marty-mj
  #205
Old 12-17-2023, 06:18 PM
Stielow's Avatar
Hi Mark,
Quick Question.
I’ve never had a problem, but I just had the Dutchboys paint them. Not sure on the process.
Stielow Engineering
  #206
Old 12-17-2023, 06:20 PM
Stielow's Avatar
Stielow Engineering
The Following 6 Users Say Thank You to Stielow For This Useful Post:
214Chevy (12-18-2023), camcojb (12-17-2023), EVIL SS (12-18-2023), fleet (12-20-2023), Goosesdad (12-20-2023), syborg tt (12-18-2023)
  #207
Old 12-18-2023, 09:43 AM
syborg tt's Avatar
Thank you I will shoot Paul a Text.
mj
marty-mj
  #208
Old 12-19-2023, 04:01 PM
Ns RS's Avatar
Ns RS Ns RS is offline
Marty I’ve had great luck with this - can’t recall but i think matt has used Eastwood chassis black on marks previous builds - project looks great mark
Old 12-20-2023, 01:26 AM
srode1 srode1 is offline
Would be great to see step by step on some of these impressive pieces. Guessing from the TIG filler rod in one picture on this one and watching other mods his preferred technique for pretty much all their work.
  #210
Old 12-20-2023, 05:56 AM
clill's Avatar
clill clill is offline
The average guy seeing the car won't notice any of these details.
Closed Thread
