08-12-2024, 02:29 PM
I really wish I remember who it was many moons ago made a power mirror set up for those mirrors
The Following User Says Thank You to raustinss For This Useful Post:
08-12-2024, 10:01 PM
Originally Posted by Stielow
I use G-Body sport mirrors. They are remote operated from the factory. They have a cable on them stock. I make new mechanical parts for them to make them manual adjustable.
I have tried a few different ways of doing it. This is not easy. I knew someone would eventually ask the question so here are a few photos. To get it to fit in the housing is a lot of trial and error.
Thanks, I will play around and copy that, like trial and error. In the 80's I tied off the manual cable inside the door and it worked but I want to do a little better now.
The Following User Says Thank You to TechNova For This Useful Post:
08-14-2024, 07:13 AM
I might be remembering wrong, but wasn't there a C3 power version?
Scott from NJ
The Following User Says Thank You to BonzoHansen For This Useful Post:
08-14-2024, 07:16 AM
Curious why G body - are the bases better suited for 1st gens? Like a better angle, etc.
Scott from NJ
08-14-2024, 07:28 AM
Hobbs Camaro (Old Drag Car)
https://www.ebay.com/itm/38719416483...mis&media=COPY
They bolt on with studs (more solid) and have a slightly longer neck.
The Following 5 Users Say Thank You to Stielow For This Useful Post:
08-16-2024, 07:34 AM
Mark, are these mirrors direct replacement for 68-69 camaro mirrors?
72 Camaro RS:SOLD
68 Camaro:
The Following User Says Thank You to 72Z/28 For This Useful Post:
08-16-2024, 08:13 AM
Define direct replacement. It is not a direct replacement. Some assembly required.
08-16-2024, 08:13 PM
Thanks for the reply. I mean if the base of the G Body mirror and the stud spacing match with the 68 camaro mirror base, so there is no need to drill holes at different locations to fix the G Body mirror.
72 Camaro RS:SOLD
68 Camaro:
08-18-2024, 05:05 AM
Yes you need to drill two holes and sort out what to do with the remote mirror control on the drivers side.
The Following 2 Users Say Thank You to Stielow For This Useful Post:
08-20-2024, 04:36 AM
The Following 15 Users Say Thank You to Stielow For This Useful Post:
03fridge (08-20-2024), 214Chevy (08-20-2024), camcojb (08-20-2024), colorado80439 (08-20-2024), dhutton (08-20-2024), dontlifttoshift (08-20-2024), fleetus macmullitz (08-20-2024), Goosesdad (08-20-2024), Juggernaut (08-20-2024), Ketzer (08-20-2024), PTAddict (08-20-2024), Roger M (08-20-2024), srode1 (08-20-2024), syborg tt (08-20-2024), WSSix (08-20-2024) |
