Old 05-23-2023, 09:41 AM
EVO EVO is offline
How is it that Sled Alley manages to keep the floor and shop so darn clean??? (asking for a friend )
Stoked to see another Camaro coming along Mark, great work.
E.
Old 05-23-2023, 09:58 AM
For this car I’m starting with a 2015 Z 2/8 spec LS7. The Z2/8 program manager fixed a few critical issues with the LS7. The engine is a rock solid 525 HP in a hot rod. It should be brick reliable and very civilized. If I don’t like the 525 HP, I can yank it out and drive over to Brian Thompson’s and “fix” it.
Mark
You're gonna want more power. Remember the Mule? GREAT looking car and engine package. But Charley was bored to tears as it was by far the slowest car he had lol, hence the twin-turbo project. I love the idea of N/A and the big block look, but I'd want at least another 100 hp over what you've planned, and only do it once. Just a thought from an arm chair QB...
Old 05-23-2023, 11:24 AM
Stielow's Avatar
Stielow Stielow is offline
E.
Matt and crew at Sled Alley clean the shop everyday. Always looks great. His attention to detail is very high.
Stielow Engineering
Old 05-23-2023, 02:33 PM
OLDFLM's Avatar
OLDFLM OLDFLM is offline
Default LS427 or LT4
A 600+hp/550lbft LS427 NA stroker seems doable with MPFI for the big block look you're after Mark... or a lightly modded LT4 dressed with a cross ram Z/28 air cleaner on top?!
Ty Ingle, USAF Retired
FREEDOMBIRD
Old 05-23-2023, 06:33 PM
Stielow's Avatar
Do an engine bay like this but not an A/C car but the factory BBC heater core box.
Stielow Engineering
Old 05-23-2023, 06:53 PM
That's hot. I think this is a great look. The engine bay is amazing.
Old 05-25-2023, 04:27 AM
Stielow's Avatar
Like this.
Stielow Engineering
Old 05-25-2023, 07:58 AM
130fe 130fe is offline
Thumbs up
Mark, are you going to be using a Holley system for harness/PCM? Are you using the Lokar LS Classic pieces to dress the engine up? Looks great!
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 05-25-2023, 01:46 PM
Stielow's Avatar
Yes Holley ECM. I will use a few Lokar bits like the valve covers.
Sled Alley is going to build the cowl air cleaner.
Stielow Engineering
Old 05-25-2023, 02:15 PM
Like this.
Looks great. Does it fit if you spin the TB 180 degrees?
