Old 05-24-2014, 09:13 AM
Steve68 Steve68 is offline
"Over all it is one of the best parts I have ever designed"
and with that statement right there, you can pat yourself on the back!!!
not many can use that statement,
I was looking at the brake set up last night, very nice, well thought out,
as well as the rest of the car and shop,
Old 05-24-2014, 09:25 AM
dontlifttoshift's Avatar
Thanks. I was just curious if the bearing saw a different load at zero camber as opposed to negative camber on a the applications you listed.
Donny
Old 05-24-2014, 09:59 AM
Mark
I'm sure your more then busy with work,car,house,shop etc etc etc but, can you tell me is the "kit" going to be made to use on a 12 bolt? Or would it have to be modified?. Do you have any idea as to when DSE will be selling them? And finally cost. Reasons are I'm about to cut my factory rear end and was planning on using the gmr hybrid floater set up but I do like your set up more any help is greatly appreciated so in advance,
Thanks Ryan Austin
Old 05-25-2014, 03:20 PM
jonesmoto jonesmoto is offline
Mark,
Are the wheels powder coated? If so, would you happen to know what color that is called? By the way, LOVE everything about the car and shop!
Old 05-25-2014, 06:05 PM
Musclerodz's Avatar
Originally Posted by raustinss View Post
Mark
Thanks Ryan Austin
should work on your 12 bolt as well as long as you change over to the correct ford ends Mark used.
Mike Redpath
Musclerodz & Customz
facebook page
Old 05-25-2014, 07:16 PM
Well I'd prefer to not have ford parts lmao
Old 05-25-2014, 08:30 PM
Well it's. It not really a Ford part it's more of a Ford shape if it makes you feel better. It works for me.
Edit, it's not a ford based. The backing base is welded directly to the axle tube.
I am willing to bet it will be available as an option if when you buy a housing, similar to what SpeedTech offers.
Old 05-25-2014, 10:44 PM
frankv11's Avatar
frankv11 frankv11 is offline
Well I'm sure I'm not the only one on the side lines waiting on release date. " please put me on the list ASAP"
Mark will custom bearing be an option on the kit incase I wanted to run Delphi ABS?
Or maybe better question should be which unit is more readily available Delphi or bosh.
Congrats on a very well made product.
Old 05-26-2014, 08:07 AM
wiedemab's Avatar
wiedemab wiedemab is offline
We run a very similar SKF bearing on the CTS-V, ZL-1 and Z/28 and we have had very few issues with them. It was one of the parts on the Z/28 that needed no upgrades during development. One set lasted the 24 endurance run on the Z/28 and were still tight and we are still running them. The 24 hour test is a accumulated 24 hour run where we just swap brake pads and tires and run the car flat out on track for tank fills of fuel.
On Red Devil, Mayhem and Chris Smiths truck they all still have almost no backlash. They also require zero maintenance.
Over all it is one of the best parts I have ever designed.
Mark
Glad to hear that! -- Very cool part for sure.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 05-27-2014, 07:58 AM
RussMurco's Avatar
RussMurco RussMurco is offline
Is this bearing currently available over the counter or is this a special piece you are having made?
Mark
Coming from you, that's saying something!
Russ "Murco" Murray
http://i1339.photobucket.com/albums/...psc7bc7b5c.jpg
"Liquidating excess cash through the automotive hobby!"
