10-09-2024, 02:30 PM
Originally Posted by CJD Automotive
While it does stick out a good bit, remember there is no tension on a dry sump belt. The drive mandrel and spacers are aluminum, so don't weigh much, and small in diameter, so not much centrifugal force. Unless your spinning it 10,000 RPM, I wouldn't be too concerned. I'd probably be more concerned with belt protection on a street driver. Not sure if you have a belly pan under the nose/engine? if so, I'd still want some protection from top in case the serpentine belt cam off, or broke, so that it wouldn't knock the dry sump belt off. Maybe that's overkill, but I put a shroud on mine. Very least, set up an oil pressure safety that kills the engine, in the ecu.
Much appreciated, I will shroud as you suggest and I agree with the loss of pressure engine kill. Thanks again!!
The Following 2 Users Say Thank You to Goosesdad For This Useful Post:
10-09-2024, 02:42 PM
Mold is done, giving it a full week to cure before busting it out. Finally! 19 section mold. That was tedious.
The Following 5 Users Say Thank You to Goosesdad For This Useful Post:
10-10-2024, 03:54 AM
The hours of labor in this project is unbelievable. Are you keeping track of them or is it something you really don’t want to know? Lol
You truly have an impressive one of a kind car. Keep up the great work because we are all dying to see this one completed.
Chris
The Following 2 Users Say Thank You to Tinker For This Useful Post:
10-11-2024, 06:16 PM
Originally Posted by Goosesdad
The fear with some I've spoken to is the torque on the crank, bearings and the pulley with this hanging off the front.
Though some think it's no problem.
That will not be a problem at all. Think about the guys running the 6-71 and 8-71 blowers with the pulley mounted to the balancer. I’m sure the tension on that belt is nowhere near what’s needed for the blowers.
Everything looks amazing! You have mad skills! 🤙🏼
-Matt-
'61 Biscayne ~ AKA BISKWIK
10-15-2024, 07:09 PM
Thank you Chris
10-15-2024, 07:11 PM
Great point, appreciated! Thank you Matt!
10-15-2024, 07:31 PM
Mold done, demo'd the plug. Some cleanup on the mold before making the actual part.
The Following 10 Users Say Thank You to Goosesdad For This Useful Post:
10-23-2024, 07:10 PM
Originally Posted by CamaroAJ
I'll send you the address lol
See you at Sema
10-28-2024, 08:02 PM
Originally Posted by syborg tt
See you at Sema
Looking forward to it!! See you there.
The Following 3 Users Say Thank You to Goosesdad For This Useful Post:
10-28-2024, 08:05 PM
Gelcoat on the mold.
The Following 7 Users Say Thank You to Goosesdad For This Useful Post:
