Old 04-09-2025, 09:23 AM
HEEP's Avatar
HEEP HEEP is offline
Originally Posted by ScotI View Post
Intake swap..... From what to what?
The PSI Intake, which I beleive is their proprietary intake, to the Holley Brand intake. It allowed me to use the Lokar covers, and turn the injectors to the inside of the fuel rails, where the other intake was a little different and didn't allow the connector of the injector on either side of the rail.
Thanks,
Bill
Bill
My Build Thread;
https://lateral-g.net/forums/showthread.php4?t=40557
The Following User Says Thank You to HEEP For This Useful Post:
camcojb (04-09-2025)
  #262
Old 04-10-2025, 07:57 AM
ScotI ScotI is offline
Thanks,
Bill
TY for the response.
I intend to so an LS swap but want to maintain the carb/old school visual. I didn't realize a certain intake might be an issue over others if wanting to use the faux BBC covers so the clarification helps.
camcojb (04-10-2025)
  #263
Old 05-31-2025, 01:55 PM
HEEP's Avatar
So it has been a while since I posted, but there has been a lot of work going on in the garage. As I have been working on wiring, getting it routed under the intake and such. Then moved to the trans tunnel. I had made a template, and a friend was going have his metal shop that does work for him to bend it up for me. Waited for over two months, and nothing. So, I went and picked up some metal, and decided that since another friend has a metal break, then we would give it a try. I will say, it worked.
Bill
My Build Thread;
The Following 2 Users Say Thank You to HEEP For This Useful Post:
camcojb (05-31-2025), WSSix (05-31-2025)
  #264
Old 05-31-2025, 01:59 PM
HEEP's Avatar
Before I welded it in, I put the seat belt bolt backers in place, and also cut the hole for the shifter. I also welded in thicker material under the shifter opening, so that I can put on a rubber boot.
Bill
My Build Thread;
  #265
Old 05-31-2025, 02:06 PM
camcojb camcojb is online now
Great work!!
Old 05-31-2025, 02:09 PM
HEEP's Avatar
Moving on, preparing for the engine harness to go through the firewall, I decided to use bulkhead connectors. If I ever need to remove the engine, just twist the plug and remove.
I then got the engine reinstalled into the car, to do more test fitting. Now, it is time to cut the harness and work on getting it all in place under the dash.
Bill
My Build Thread;
  #267
Old 05-31-2025, 02:10 PM
HEEP's Avatar
Now for a question. There is a connector for the A/C Pressure switch. On a Vintage Air unit, will it be in the inside of the car? Not sure where it would be on the outside.
Thanks.
Bill
Bill
My Build Thread;
Old 05-31-2025, 02:35 PM
Thanks.
Bill
The ones I've had are usually built into the hard lines right at the condenser or in the drier itself. I use a trinary switch (instead of binary) if using electric fans.
Old 05-31-2025, 02:37 PM
HEEP's Avatar
Thanks Jodi. I thought it may be there, but wasn’t sure.
Bill
My Build Thread;
  #270
Old 05-31-2025, 08:37 PM
Good work on the tunnel, Bill.
