Go Back   Lateral-g Forums > Technical Discussions > How To's, Tips, and Tricks
Old 01-18-2025, 12:07 AM
572Camaro's Avatar
Default Drill Bits
Okay, ever find yourself at the drill press with over 400 drill bits
which are ALL DULL?
I routinely drill stainless, mostly 1/2” diameter and smaller.
Please share any advice or tips regarding sharpening drill bits.
Anything you can.
I know there are jigs, grinders, etc..,
But what do YOU recommend?
I welcome anything you share.
Old 01-18-2025, 10:06 AM
68454RS's Avatar
68454RS 68454RS is offline
The Following User Says Thank You to 68454RS For This Useful Post:
camcojb (01-18-2025)
Old 01-18-2025, 10:17 AM
jsr69's Avatar
jsr69 jsr69 is offline
I us the Drill Doctor and have had great success. I don't try to sharpen any bits smaller than 3/16".
Steve Spoor
69 Rally Sport with Quadra-Link, Wayne Due C-4 Subframe, T-56, 420 SB2.2
67 Chevelle, Art Morrison Chassis, 416 LS3, T-56 (under construction)
The Following User Says Thank You to jsr69 For This Useful Post:
Old 05-02-2025, 08:31 AM
572Camaro's Avatar
Well, I ended up buying a “Drill Doctor”. It works great. Even greater tho, is that my daughter is using it to sharpen my 400+ drill bits for my birthday present. It just don’t get no better!
The Following 3 Users Say Thank You to 572Camaro For This Useful Post:
68454RS (05-02-2025), camcojb (05-02-2025), Roscoe03 (05-06-2025)
Old 05-02-2025, 10:17 AM
raustinss raustinss is online now
stainless needs to be sharpened at a different angle than what you would want for mild steel 135 ish degrees for S.S. mild steel 120 ish . Also use cutting fluid lots of pressure on the bit and a slower drill speed
The Following 2 Users Say Thank You to raustinss For This Useful Post:
camcojb (05-02-2025), kwhizz (05-08-2025)
