Old 02-04-2026, 09:23 PM
confern confern is offline
Originally Posted by thedugan View Post
If you run the corvette regulator by the tank you will only need one line to the front of the car. Two lines to the tank.
https://www.summitracing.com/parts/a...model/corvette
Ahh ok. Are you saying just cap off one of the fuel rails outlets on the firewall side? Then use a crossover tube in the front then one line on the firewall side back to the corvette regulator then 2 lines into the supply and return at the tank?
Old 02-04-2026, 09:26 PM
Ahh ok, just saw this post. Thank you
The Following User Says Thank You to confern For This Useful Post:
camcojb (02-04-2026)
  #13
Old 02-05-2026, 06:10 AM
thedugan's Avatar
thedugan thedugan is offline
Here is a picture of how it can be done. It's the simplest and most effective way todo your fuel system. You will have zero issues if you do it this way.
https://www.tanksinc.com/img/efils9904.jpg
As Jody mentions, the VaporWorx setup is also an option. For your 5.3 it could be used if you wanted to. They have a system for an NA setup like yours. https://aeromotiveinc.com/pages/vapo...Mj9JW94UMZBMGC
I run that on my supercharged LSA Camaro as I need more fuel pressure than the Corvette Regulator can provide. So easy to install, works amazingly, and the pre- and post-support is top-notch.
Doug L.
68 Camaro RS/SS Conv. LSA/T56
67 Camaro RS LS2/T56 "NutKse"
The Following User Says Thank You to thedugan For This Useful Post:
camcojb (02-05-2026)
  #14
Old 02-05-2026, 09:03 AM
Originally Posted by dhutton View Post
I run hardline front to back roughly following the factory lines. Then short AN lines at the tank and fuel rail. I’m not comfortable running soft fuel lines front to back.
Got it, thanks.
  #15
Old 02-05-2026, 09:04 AM
Thank you for all the good advice.
  #16
Old 02-05-2026, 11:12 AM
dhutton dhutton is offline
If you use the corvette FPR only use AC Delco or Wix. The rest are garbage and can’t be relied on.
The Following 2 Users Say Thank You to dhutton For This Useful Post:
camcojb (02-05-2026), confern (02-05-2026)
  #17
Old 02-05-2026, 01:03 PM
Adding a few new holes in the floorpan for clamps on the rubber lines will be needed. Better to secure it away from any heat or vibration vs having a fire.
Best option for fuel line long term is a hard line front to rear with the AN line to the tank and to the rails. Runs along the stock path. Couple clamps to hold it down and away from vibration or heat sources.
I use the Right Stuff line and cut and flare it for AN. One cut and flare near the tank. AN adapters for feed to the regulator. AN lines to the tank from the regulator. Another cut and flare near the passenger footwell area by the subframe. AN line to the fuel rail.
https://rpui.com/the-right-stuff/pre...t/Model/Camaro
I buy the Fragola premade AN lines to make my life easy. Leak free everytime. No AN lines to make that I have to pressure test for leaks. I do pressure test the entire system and blow it out before I run gas thru it.
https://www.summitracing.com/search/...0an%20fittings
What size Right Stuff fuel line do you run? I see they offer 5/16" and 3/8".
  #18
Old 02-05-2026, 01:42 PM
Originally Posted by confern View Post
What size Right Stuff fuel line do you run? I see they offer 5/15" and 3/8".
Normally 3/8 feed and 5/16 return.
  #19
Old 02-05-2026, 05:16 PM
Ok thanks.
  #20
Old 02-05-2026, 06:37 PM
Ok, so the feed line from tank to regulator is 3/8? Then the return from regulator to tank is 5/16? Then what size from regulator to fuel rails (passenger side floor board), (5/16" or 3/8")? Sorry for all the questions, this is my first time doing the LS stuff my last build I did all stock stuff.
