Old 08-12-2008, 06:10 PM
Originally Posted by 4OfaKind View Post
I am planning a TT 383.
Do you have one tank for each valve cover or do you only need one tank off one cover for the whole engine?
If I ran a return drain line back to the oilpan will it defeat the purpose of the PCV system?
Mal
I run one tank per side. I do not run a pcv on a forced induction engine. A drain back to the pan is fine and eliminates having to drain the tank, but many like to get that cruddy milky oil out of the engine (take a look inside a breather tank sometime), so they keep it separate and drain periodically.
