Old 01-12-2009, 08:53 AM
Rusty G Rusty G is offline
Default Any Negative effect of raised lower ball joint?
First, my car is a true daily driver (Gbody) that I want to lower the front about an inch.
I have good springs that are not going to be replaced.
I have a extra set of stock upper and lower A arms that I am going to "rebuild" and install.
My idea is to combine a raised lower balljoint along with a raising the mounting point for that ball joint to drop the car 1".
I looks like with some minor trimming/welding raising the mount should not be hard at all.
From my limited understanding of suspension dynamics, I think this may slightly help the stock camber curve. Yes?
Also planning on adding a tall upper balljoint at the same time.
I "think" these will compliment each other, correct?
The true goal is the 1 " drop without hurting handling, any improvement will be a bonus.
