Old 03-16-2009, 06:25 AM
Payton King's Avatar
Default Here you go
Since we are basing it off of the stock pedals. We need to drop the pivot point of the brake pedal down to get a straight shot at the masters. We could not move the masters up because of the cowl. The stock point is used for the clutch pedal and Jim made a new point for the brakes. Sounds funky but works like a charm. I am running 6:1 pedal ratio, 5/8 on front and 3/4 on the rear. Not standing on it but with a good amount of pressure, I developed 1200 psi on the front and 1100 psi on the back. Once I get the bias adjusted I thing the leg pressure is going to be the best I have had. 1200 psi is the max reccommended on a Wilwood caliper, so after I get the bias right and if I am generating too much pressure, I will size the masters up one step. Lots of trial and error but I am close to getting it nailed down.
