Thought I would post this over here and introduce myself since I have just lurked on lat-g for a while now.  I'm another Canuck locked in an endless winter and dieing to drive his recently finished (for now) Chevelle.  I've learned a lot from the forum and it helped me solve some of the issues I ran into during the build.
I held off on creating a project post as I ran into a lot of major setbacks and issues that dragged this out longer than planned (just like every project car).  It started 2 1/2 years ago when I mistakenly purchased somebody else's project that they didn't have time to finish.  The car had been fully disassembled and the frame, suspension and miscellaneous parts powdercoated.  It came with a th400 and a fairly fresh small block.  Everything was there and while I knew it needed new rear quarters the body seemed decent.  I got a decent price for around here and took my prize home in 2 trips with a trailer and about a thousand boxes.  The plan was to assemble what I had and to get it on the road and then make the changes I wanted later.
This is what it looked like then:
The problems started right away when I decided I wanted to get rid of the 350 and auto go big block/5speed right away.  I sold the small block and most of the stock suspension and tranny right away.  That freed up some room in the garage and some cash which was great.  I then went ahead and ordered a fresh moser 12 bolt with trutrack and ford axle ends from Frank at GP superstore.  I also ordered a 540 from Wolfplace to power the beast.  The next major problem came up then.  When I installed the dif and started measuring for the backspacing I discovered the frame seemed out of whack in the rear.  I had measured the diamond when I bought the car and it was square so I was baffled.  I took it to a frame shop and asked him to check/square the rear and correct the fame sag in the front.  He measured the same stuff I did and thought it was good enough to fix.  After 2 days he called me and told me he was giving up.  His best guess was that it had been hit right on the rear wheel at some point and repaired poorly.  When he started pulling the frame back welds started breaking all over and all kinds of ugliness was covered up with the powdercoat.  It might have been salvageable but I didn't want to have a suspect frame under this thing and decided to scrap it.  This was a major setback as new frames are very hard to find up here in any kind of condition.  It took me about 6 months to find another one and it looked like this:
I spent 2 moths grinding, welding, gusseting and painting with por15.  I reinforced all the week points - front LCA mounts, rear LCA mounts, rear crossmember etc.  I decided not to box the full frame rails as I do not believe the benefit is worth the hassle of changing the tranny crossmember mounts and brake and fuel line routing.  Once the frame was done I installed twin 1/2" SS fuel lines (supply and return) and new ss brake lines from inline tube, sc&c stage 2+ front suspension plus SPC lca's, edelbrock adjustable uppers and UMI adjustable lowers in the rear.
For now I'm running bilstein shocks with circle track springs with adjusters in the front.  Next winter I may go coilover or at least varishocks depending on how it performs this summer.  I also ordered up some c5 Z06 front brakes from Kore3 along with their al hubs.  I found some LS1 rear brakes for the back .
Next to arrive were some more driveline goodies:
Followed by some pretty forgelines (18/9.5 front, 18X11 rear)
The real excitement arrived in a really big crate from northern California:
It's a dart block 540 from Lewis Racing Engines.  It made 746HP and 680ft-lbs on his dyno.
To be continued...
