Old 06-02-2009, 09:02 PM
ohcbird's Avatar
ohcbird ohcbird is offline
Default TKO TR-3550 5 speed trans kit
This is an early TKO kit- (I believe it's a Keisler trans kit, no receipts)
1. TR-3550 Trans (an early TKO, 425ftlb capacity), 4400 miles, has a mechanical and electronic speedo output. 3.27 1st gear, .68 overdrive. Info for trans from TTC (tag # 2600 708): http://www.ttcautomotive.com/English...ts/TR-3550.asp
2. Mcleod steel bellhousing+ adapter plate+ clutch fork + mounting bolts
3. Hurst shift handle with white ball
4. Centerforce clutch, USED (no flywheel) + mounting bolts
5. Keisler crossmember + mounting bolts
6. Trans mount
7. Z-bar assembly (not pictured, but complete- from the rod that attaches to the clutch pedal to the clutch fork) **I might be motivated to sell the whole pedal assembly**
8. Driveshaft assembly for a 1st gen / 12bolt (not pictured, in storage)
Trans is located at Jake's Rod Shop in Maine, $1300 + shipping PM me if you are interested.
JEFF
