Old 06-08-2009, 07:56 AM
69MyWay's Avatar
69MyWay 69MyWay is offline
Lots more to come...
The engine came in on Friday - I got it out of the crate and on teh stand. The seller did a first rate job of crating it up - very happy with that.
The car isn't here yet - so it will be a bit before I know exactly where to cut/trim...etc.
Some things I see right away.
#1 - pan is way too deep - it falls 3" below the teeth on the flywheel. It is aluminum and shouldn't be a problem having it shortened - I was told they are not compatible with standard big block pans
#2 - It has a cool cam sensor in the front cover, and the crank sensor is on the back of the block on the bellhousing behind the driver head shooting down to the back of the crank.
#3 - The cross over tube on the heads take the place of the old heads and intake mounted thermostat housing
The knock sensors mount low on the block just like the early efi small blocks.
The engine looks really cool in person - and HUGE.
Won't have a whole lot new for at lease a couple of more weeks
I need to get some pics posted of it on the stand from different angles.
