Old 11-04-2005, 02:47 PM
cutlasskid cutlasskid is offline
Default g-body hook up
any of you guys good at rear suspensions i would like to get my car to hook better on the street using 10 inch tires i heard the g- bodys have a good factory 4 link and that they will bind up when you start making power. i have installed boxed control arms upper and lower the pinion angle is at 4 degrees but i was going to change to adjustable upper and i seen this kit you weld on to where the lower bars bolt to rear end that move the mounting point a couple inches lower but i read you want the lower bars some what level to the ground? and there are other items out there but who knows if they work im tired of spending money on things that dont work and i dont want to mini tube or add after market 4 link being twin turbo i fell this should be a easy task due to less power out of the hole. unless you drop the clutch.
