  #30
Old 06-09-2010, 04:36 PM
ccracin's Avatar
ccracin ccracin is offline
Vic ---
I know people mean well... and usually bite my tongue - but bad info is not what this forum is all about. And that was just plain BS info wise. Can't have people come on here and put up info that might be taken as "gospel" by some less knowledgeable person. We have to remember that LOTS of people read this stuff -- and many aren't members even... Any given day - there are usually more people reading than there are members.... So you (not you personally) post up crap info and people go way either thinking that Lat G is a bunch of bozos and not worth joining -- or newbies go away with some garbage info stuck in their sweet little heads.
Almost ANY of the real gearheads on here - would tell you (confirm) that Pauls timing statement is just BS. I don't know where he got that - I've certainly NEVER heard a rule like that - EVER... and I've been doing this stuff for going on 40 years now... lots of motors - lots of races - lots of car builds... I'm sure he meant well - and probably believes his statement - but he shouldn't because it's not correct.
Well said Greg. I agree that piece of info is as far from the truth as it can be! Go to any Dirt Late Model race and you will see 14:1 motors locked out at 30+ degrees. An engine is an assembly of systems that need to work correctly for the whole to work. One problem can be caused directly by another. A thorough walk through of one thing at a time verifying each area is correct no matter how insignificant it may seem is sometimes the only way to solve an issue you have been working on for a long time. When frustration sets in you start going blind. (Figuratively) Step back and start at the beginning. I don't car how many starters you bought, get another one. Start over with the alignment and go from there. Breathe and take it one step at a time, but do it with a different starter. Good luck.
Chad
Instagram - @cctek
68 Chevy Pickup Project
