Old 06-11-2010, 09:53 PM
NOT A TA's Avatar
NOT A TA NOT A TA is offline
Sunday I had some extra time while waiting for a SBC 400 to be be readied for decking so I did mine and took some pics for those that have never seen how it's done. This is not the latest, greatest, fancy machinery but gets the job done accurately.
Anyway "decking" the block involves machining the surfaces where the cylinder heads bolt on so that it's perfectly flat. In this case I took off about 10 thousandths of an inch. This is done by having the block move back and forth under the spinning head with a cutting bit in it. The block moves back and forth because the table it's sitting on moves rather than the rotating head. The process involves about a half dozen passes. The first pass very light to allow corrections to be made followed by passes where 1.5-2 thousandths are taken off with the last pass being made at a very slow table movement speed to get a nice final surface finish. Here's the basic steps involved....
First get a bud to help heave the block up onto the machine. There is a large bar that the main bearing journals rests on which is level with the cutting head. A bracket is bolted into the deck of the cylinder bank not being machined which gets an adjustable "foot" placed under it. Then a big file is used on the surface to be machined to pick off any lumps bumps or other abnormalities.
Next a straight edge is used to check for any warping. It's not unusual for a deck to have a bit of crown or bow but it's necessary to know before leveling the block
Then a very accurate level is used to level the block front to back and side to side. The adjustable foot is used for the side to side adjustment, and to make any minor front to back adjustment a piece of paper or two are used between the bar the block is sitting on and the main journal surface. There is fancy new equipment to level and rotate blocks but this is the basic old fashioned way, the new ones just make it easier for the machine operator. The block is not bolted solidly in place. It's just sitting there held only by it's own weight.
A very light first pass is made to check and make sure the deck is square with the cutting head in this case it was perfect! You can see that the cutting tool is just skimming the surface and touching both sides of the deck or grazing the surface from side to side like between the cylinders.
Then succeding passes are made and in the pic below you can see the bit is cutting almost the whole surface except a few small areas.
And then on the final pass which is done at a slow table movement rate the surface is done. After the final pass you get a bud to help pick up the block and flip it 180 degrees so you can do the other deck surface and start all over. File straight edge, level, light pass etc. If we're decking a block say 35 thousandths or something to raise the compression we would drill register holes in the deck to the correct depth ahead of milling and would also mill the ends where the intake manifold would sit. With my block since I was only taking off a little bit neither of these steps were necessary.
John Paige
lab-14.com
