  #13
Old 07-07-2010, 08:17 PM
SR71 SR71 is offline
the idle is pretty radical...along the lines of a 305 magnum from comp.
heads are aftermarket vortecs from racing head service in memphis. they flow a nice bit more than stock and have the correct comp springs and screw in studs/guideplates as delivered. compression is 9.5:1.
it will work fine with an auto. if you use a lock up converter, you will have to experiment with lock up points.
