Old 10-05-2010, 05:57 PM
scherp69's Avatar
scherp69 scherp69 is offline
Default Should I cut this metal out?
I actually have two questions, the first, as the title says, I'm wondering if I should cut this metal out or if it will be okay. I found a few spot on the windshield channel where it is pitting like this. There are a couple spots that are obvious and need to be cut out. Is there anything that I can use to replace the stock mounting tabs for the chrome trim if I replace a bunch of the metal?
I'm going to cut out this part, but that's the tab I'm talking about.
This is what the metal looks like where I'm wondering about.
I'm also wondering about some rust in the drip rails. I don't plan on smoothing them or I wouldn't be too worried, but I'm wondering what I can do about the bit of rust that's at the bottom since I plan on leaving them. I will be putting sealer back in.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
