Old 01-25-2011, 05:19 PM
rat_rod_russell's Avatar
rat_rod_russell rat_rod_russell is offline
Default 57 Chassis C4 Corvette Front and Rear, Stage 4 + SS Kit + 32 Gallon Fuel Tank by Hot
One we built for Don in San Antonio, Hes close enough for me to go take photos for him and post up. He's got a 57 4 Door Sedan and a 2 Door Hardtop he can't decide which to put on the chassis just yet.
The highlights
Hot Rod Jim C4 Frame # 46
Stage 4 rolling chassis
92 Corvette suspension front and rear
Dana 44 Differential with 3.73 gear upgrade
SS kit
  • QA1 dual adjustable coil over shocks
  • Front and rear adjustable sway bars
  • Adjustable rear 4 bar (this really helps dial in your launch with a C4 rear)
Hot Rod Jim Custom 32.5 Gallon fuel tank
  • Aluminum Tig welded
  • 255 LPH Fuel Pump (650 HP @ 60 PSI)
  • 0-90 ohm sending unit
  • all AN hardware
  • easily removable flex lines from under the car
  • quick drop cradle
  • NOTE: You do have to take out the spare tire well to fit the tank
PT-57
1957 Chevy Truck, 6.0L LS, T56, STS Twin Turbos, C6 Corvette Suspension, CAD Designed Frame by Hot Rod Jim's.
https://lateral-g.net/forums/showthread.php4?t=20292
http://www.nerdrods.com
