  #22
Old 01-10-2012, 05:00 PM
Thomo5150 Thomo5150 is offline
Planning is the key, trust me for ever change I make to the Effy something else must change too. I've widened the chasssis so I must mod cab mounts and the front horns to bolt the radiator support on. No big deal but there are subtle changes that needed to be made which you must get rite in the planning process. Ride height was critical for this project and there are so many limiting factors as well. When I researched ride height with IFS on F100's I needed to determine what ride height I could achieve with the Vette drivetrain. There where a lot of Jag IFS swaps for Effys and the new trend seemed to be the Ford Crown Victoria IFS swaps in the USA. Here's something I learnt by studying one of these swaps which I then had to factor in to my conversion.
72 F100 CV cradle fitted.
The guy did a nice job and it was set to the factory spec's of the wheel centreline.
He put some 20's on which I liked and could see what my F100 would look like.
Here's the suble change I needed to make in the planning. I liked the ride height but I new mine would be lower. I notice the tyre is set forward and the gap doesn't look rite to me.
The guy then lowered the F100 1.5 inch which made the wheel location stand out more.
Things like this which need to be sorted before you start cutting or welding will make or break a swap and the way it looks. How many of you would think that I mucked up the wheel centreline location if I left it in the factory spec location. The change being made to where the centreline of the wheel is for this conversion is not easy, I had to determine the length of the wheelbase of 116.9 inch and subtract where I thought the wheel centreline should be then that change had to be factored in to the torque tube length before I ordered it.
Just one problem on my list, I think if I listed them I'd have to longest build thread...............
