Go Back   Lateral-g Forums > Vendor Specific Technical Discussions and Support > Roadster Shop Chassis and Components
Old 03-21-2012, 10:19 AM
Roadster Shop's Avatar
Supporting Vendor
RoadsterShop.com
Default FAST TRACK 1967-69 Camaro IRS Chassis
Introducing the Roadster Shop Fast Track IFS/IRS Camaro chassis. The only full frame, full independent, full performance chassis system on the market for the first Gen Camaro.
Standard Features
• RS Fast Track Front Suspension
• C6 Corvette spindle and Z06 hub assembly
• Adjustable Afco billet coilovers
• 1.25" splined front sway bar with C6 Corvette end links
• Custom fabricated, fully boxed, 10 gage frame rails
• Utilizes all stock body mounting locations, bumper and core support mounts
• Lowered ride height
• Engine mounts for SBC, BBC, or optional LS Motors
• Custom center cross member with adjustable, drop out trans mount
• Mid brace cross member with exhaust ports for up to 3" exhaust
• RS Fast Track Independent Rear Suspension
• Ford 9” based center with C6 Corvette spindle
• Fabricated 1.25” upper and 1.625” lower tubular control arms
• Custom 300M drive axles with machined chromoly 930 CV joints rated at 1,000 HP
• Custom machined 300M, high HP inner and outer stub axles
• 1.25” splined rear sway bar
Performance
• Designed to accommodate a 10” wide front wheel with up to a 295 series tire, and a 12” wide rear wheel with a 345 series tire
• Controlled roll center, matched front to rear, for predictable performance
• Matched front and rear suspension camber curves.
• Built in caster and camber street settings, easily adjustable for track set ups
• Optimal motion ratio for accurate spring ratings yielding comfortable ride and exceptional performance
• Delrin control arm bushings to reduce deflection and maintain suspension settings and ride quality.
• Light weight components for lowest unsprung weight without sacrificing strength
• C6 Corvette spindles, hubs and lower ball joints
• Performance Improvements over Stock Corvette Geometry
o Increased Negative Camber Gains
o Increased Wheel Clearance (to Control Arms)
o Increased Strength
o Drastically Reduced Bushing Deflection
Pricing and additional information can be found on our website at:
http://www.roadstershop.com/products...camaro-chassis
