Old 06-11-2012, 02:55 PM
geberhard's Avatar
geberhard geberhard is offline
Default New in BOX SSBC Disc Brakes with all upgrades, finish, etc complete spindles, booster
UPDATE - ALL SOLD
I bought this setup for a project, however am not going to use it right away, and could use the funds instead for my other projects.
It is a complete SSBC A123-1ADS Brake kit, retails for 1569.95 without upgrades. link to kit http://www.ssbrakes.com/commerce/detail/?nPID=8315
I have the setup with teh Polished finished super twin pistons, etc.
Setup is complete only out of the box for a few pictures. New never installed.
Specs form the site:
Product Features
SuperTwin 2-piston Drum to disc brake conversion kit with 11 in. rotors; power. Includes new 2 in. drop spindles.
Calipers come with Clear Anodizefinish. Optional polishing or powder-coating available.
Can reuse stock upper and lower ball joints.
Direct bolt-on using factory or aftermarket replacement A-arms.
Includes SuperTwin HD 2-Piston aluminum calipers.
Includes Turbo slotted rotors with Xtra Life plating.
No longer forced to use small G-Body brakes typically found in drop spindle kits.
Stock steering arms bolt to the same location as on the stock spindle, keeping the steering geometry unchanged.
Will not fit most Pontiac factory wheels.
Works with virtually any aftermarket steering arms, including rack and pinion kits.
Complete with 9 in. booster, master cylinder, spindles, pads, caliper mounting brackets, adjustable proportioning valve, lines, seals, bearings, grease caps, braided stainless flex hoses, spindle nuts and hardware.
Vehicle Applications
1964-1972 Buick Skylark
1967-1969 Chevrolet Camaro
1964-1972 Chevrolet Chevelle
1964-1972 Chevrolet El Camino
1964-1972 Chevrolet Malibu
1968-1974 Chevrolet Nova
1967-1967 Pontiac Firebird
1968-1969 Pontiac Firebird
1964-1972 Pontiac GTO
1964-1972 Pontiac LeMans
1964-1970 Pontiac Tempest
I saw this setup in person and compared with Baer and other kits out there and is one of the nicest around.
I am looking for $1400, cna ship on your dime.
I also have a rear low mileage disc brake kit I bought used in great shape I can include for an extra $250.
Located in Northern CA, Pleasanton - Dublin Area.
My finsih is similar to this one, VERY CLEAN
I will post actual pictures shortly.
