Old 12-20-2012, 06:07 AM
cp87 cp87 is offline
15 min isnt long enough for the lines to get that hot UNLESS one is resting up against your exhaust.
You have new rubber line throughout the whole system right?
What sending unit/pick up do you have?
Stock or new factory type?
How much fuel is in the tank?
I have two lines from the fuel cell to the Y block then a single line out to a 3/8 steel line along the frame up to the front fender then it goes back into rubber line to the pump, the pump to the filter then the carb.
no sending unit
about 3/4 full 8gal? if i were to guess
Thinking maybe possible tear in the diaprahm so its pumps air the system?
