Old 12-21-2012, 03:54 PM
usa-69z usa-69z is offline
Default bigger brakes on maual system
Hi , can you guide me to the right disc/calipers for my application please... My car is a 69 camaro ,, stock disc up front / drum rear setup.. I have a 7/8 wilwood master with NO booster , maual brakes with proportioning valve. Im wanting to upgrade my manual system and run larger discs (18inch rims) and calipers up front only. so what would i get best response from as a disc/caliper kit to suit the manual 7/8 master system?
I seeost bigger brake kits run a taller spindle? any reason for this? id like a bolt on kit .. does a taller spindle change any height adjustments i have made now?
there are so many kits available , it gets confusing
Gav
69 CAMARO - RIGHT HAND DRIVE AUSSIE MODEL.
383 SBC 8 STACK INJECTED EFI.
RIDETECH FOUR LINK REAR - DSE MINI TUBS .
SPEEDTECH FRONT A ARMS & COILOVERS.
MOSER 3.7 REAR- 6 SPEED T56 TREMEC.
FIKSE RIMS ETC ETC..
