Old 09-30-2013, 09:44 PM
FETorino's Avatar
FETorino FETorino is offline
So a bit of detail on what I've been up to lately.
First Cheryl and I knock over a couple banks to fund the deal. DG I took inspiration from your mauve jacket for the disguise.
A while back I posted the pictures below but without explanation.
When I ordered my wheels Travis Johnson from F43 told me about MSI racing in NC. They make custom wheel studs and lug nuts for all forms of racing including NASCAR.
Their stuff is machined in house to order and then heat treated and teflon coated. I didn't want the 12mm front 1/2" rear stud combo that you are usually stuck with when using a C6 front hub and a Speedway floater. So I ordered a set of 1/2 20 front studs for my C6 hubs from Curtis. I also ordered a matching set of studs for the rear hubs.
Kenny at Speedway was kind enough to swap me my hubs with studs for a fresh set without studs. I have been waiting for the studs for about a month. (I got stuck behind an order for 800 sets of studs).
I finally got the front hubs with the studs already pressed in and took the new rear studs and my hubs over to Bretts to borrow his press.
Then I loaded up my RAD10 Formula43 wheels and Micheline Pilot tires and went to the tire shop.
All mounted up and ready to get the car on the ground. The end result you've seen above.
Rob in SoCal
