Old 11-03-2013, 06:14 AM
RBuhr69's Avatar
RBuhr69 RBuhr69 is offline
Default 12 bolt Moser / Eaton Posi
No way bashing Moser or Eaton.....
Just curious if people are experiencing an issue when backing up in tight spots that it sounds like the rear end is fighting itself or sounds like it is tearing parts up, but its not as it all works fine. This is on a brand new 12 bolt Moser/Eaton Posi unit.
No issues going forward, no issues hard cornering forward left/right, backs up in straight line no noise, just when I back up out of my garage after car has sat. Doesn't appear to do it as bad after driving car all day when I pull into garage, and then back out again.
I did do some searches on google and sounds like it is common but didn't see much in the way of if there is a resolution to fixing it. Some comments were this is normal, some stated they added another bottle of limited slip lube beyond the required 1 bottle.
I have not called Eaton or Moser yet as I wanted to hear some conversation with people who have already experienced this issue. Did it go away with time, did adding another bottle help, did you have to have someone open up the rear and see what was wrong? Is there something that can be done to help, etc..
Thoughts?
