Old 11-08-2013, 06:14 PM
Terryd's Avatar
Terryd Terryd is offline
Default LS3/480 GMPP harness - no heat on even bank..
Hey guys/ladies.
First post here. Having some issues with an LS3/480 conversion. Hoping someone here might have had a similar issue.
A short background on the conversion. The engine is a new GM LS3/480. and the matching GMPP controller kit (harness, ecm, etc). I have a pretty good control wiring background so I felt confident in tailoring the harness to fit the application a bit better than it came out of the box.
First attempt to fire the engine: It lit off immediately, YAY! or so I thought. It was running terribly rough. Shut it down and performed the visual look over for something obvious. That is when I noticed that the header on the even bank was ice cold, odd bank was hot.
Since I modified the harness I suspected that I had made an error at some point in my wiring. To date I have run the pin outs 3 separate times. All checks out good. Tried re-firing several times with the same results.
I have checked for ignition power to the coils and injectors, good there too.
Put a Noid light on as well, shows the injector firing.
I managed to locate another harness and ECM. I overlayed the unmodified harness to confirm or deny that I had made a wiring error. Fired it up with the new harness...same result. Swapped the ECM...same result.
Anyone know of a scenario that would cause this?
Thanks and really enjoy this site! Very inspiring to say the least.
Terry
Terryd
Check out the latest project at:
http://www.67novaproject.blogspot.com/
'67 Nova SS clone PT
'06 Z06 - Sold
'72 Trans Am - sold
‘73 Trans Am - Poncho Powered PT build
