Old 07-02-2006, 09:47 PM
Fastbowtie Fastbowtie is offline
Default Oil Pressure Dropping When Braking
Ok, here's my first post. I have a little problem that has just shown its ugly head tonight. I was driving my 68 Camaro and hit the brakes moderately and happen to look down at the oil pressure gauge. It read 0. Now when the car was completely stopped it return back up to 30 lbs. At first I thought it might be the pick-up but when I tested it by accelerating it went to 70 lbs at 6000 RPM. So then I tried to turn the car right and then left to see how low the pressure would go. The lowest it would go was 20 lbs now mind you this is in a circle. You can't get too much RPM in a circle. The car is a protouring car. It has a set of sticky Nitto NTO1 on all 4 corners and a Hotchkis swaybar, springs and QA1 shocks. The Brakes are Touring Classics 13 inch 4 way discs with Hydroboost. The engine is a 350 with a stock 1970 Z28 LT1 oil pan along with the windage tray and a stock Z28 Pump. Does anybody have any idea whats going on here? Thanks Guys for the help.
