Old 11-16-2013, 04:34 PM
FETorino's Avatar
FETorino FETorino is offline
Originally Posted by gmtech921 View Post
Dig seeing the progress Rob!
Thanks Chris
How about some Parts pictures? are those good?
As I kept trimming the firewall further and further to give myself clearance to set the motor down and back it became apparent that the stock hanging pedals weren't going to cut it.
Here was the first test fit with a minimal cut. In this picture the motor was still .25" off center and you can see I have no clearance between the VC and remaining firewall. You can also see how close the 4 bolts that hold the stock pedal hanger are to the VC. I ended cutting the firewall to the other side of the mounting holes so no more stock pedal hanger.
Earlier in the week Brett had pointed out I had plenty of room for a floor pedal set up. I agreed with him but my concern was the header collectors need to go somewhere and that path would be down near the footwell. But after cutting the firewall to where I wanted it and measuring it was clear I have a lot more flexibility with fitting the floor pedals than a hanging set.
So I went shopping.
Although this is a 600 series Tilton Pedal set up it has the 900 series bracket to run the Series 77 master cylinders. The mounting of these is supposed to eliminate binding in pedal travel and the migrating of the bias due to some of the binding.
Having put the motor in the chassis where I want it to sit it is also clear that a front plate and midplate set up would make sense for mounting the motor.
The front plate will also give me a nice plane to use for the PS pump and alt mounting brackets that don't yet exist. Since I have a Peterson stackable mandrel drive I can use whatever existing PS or Alt brackets I like the look of and tailor the belt alignment via the position of the pulleys on the Peterson Mandrel. Those parts arrived long time ago so here is a reminder what they look like. This is better than digging through the wrecking yard this thread sorta is.
The Midplate will be a custom piece that Brett will fab. The front plate I got from Chris Alston Chassisworks. It has plenty of extra material I will trim off once all the final mounting positions of the motor and accessories are determined. As you can see in the photo my chief parts guy checked it all out and told me it was good to go.
Rob in SoCal
