Old 10-14-2014, 12:49 PM
captainofiron's Avatar
captainofiron captainofiron is offline
Are you sure that's how it was mounted? Also, the double sided tape can easily be bonded well enough to radically change the forces applied to the helmet. Take 3M's outdoor double sided tape, the stuff with the red backing, it's ridiculously strong. Plenty of motorcycle riders talk about the drag the camera causes, too. It's very easy to understand how the camera could cause extra damage to the helmet depending on how it is installed/attached. If the helmet fails, then his head is virtually unprotected.
I think they might be saying that instead of allowing a patch of the surface area of the helmet to take the impact (and flex accordingly), the gopro might have concentrated the load into a smaller patch or point, and caused higher stress on the helmet therefore causing it to crack
