Old 01-20-2015, 09:50 AM
paulk68 paulk68 is offline
Default More Ridetech Install questions
Installing level 2 on my 68 Camaro frame
1. Did anyone else have issues getting the lower shock to fit in the lower strong arm. with the aluminum bushings installed the passenger side just does not want to fit in the lower strong arms. should i sand down the aluminum bushing???
2. the ridetech upper coil spring retainer has about a 1/4 inch of clearance from the factory spring retainer on the subframe is that enough room or should i trim that section.
I can not believe how fragile the power coating is on these strong arms, it chips off very easily.
Paul
