Old 04-25-2015, 07:46 PM
Nativefx Nativefx is offline
Default Assistance getting right measurements for shortened rear end?
I had asked a question about the best way to get the measurements I need to order a shortened rear end on my 69 Firebird in another thread, but thought I should start my own in the rear end "section" of Lat-G.
I found this link in a thread on PT and didn't know if this would be a better way to get measurements? https://www.cachassisworks.com/Attac...structions.pdf
Here is the link to my question to Vince of Meanstreets Performance who was helping out the OP. https://lateral-g.net/forums/show...573#post603573
From what I have been able to find, most recommend you have 1" from the inner fender to the inner wheel and at least a 1/2" from the outer wheel to the outside fender. This has at least been what I've found for other running a 4 link, and I am running the RideTech Level 2 AirRide. My concern is how much movement you will see during articulation of the rear suspension as I'd like to have my wheels positioned as far out as possible, but when I look up under the fender lip it looks like the inner portion of the fender "bulges" inward before going up and curving inward. Anyone have any pictures looking up to compare the amount of space they gave themselves without any rubbing issues? And will I need more space since I have the AirRide setup and when I decide to lower in completely?
Here's a quick pic I took with one wheel positioned.
[IMG][/IMG]
I just don't want my wheels set back to far in, but I also don't want any rubbing issues or my tires setting on the inner fender when its lowered completely. We set the wheels on dollies to move around and also lift closer to the estimated ride height but this made it very FRUSTRATING when trying to take an actual measurement and ANY slight but would move the dolly
Since I'm running 325/30/19 Pilot Super Sport tires on Forgeline 19 x 11.5 rims with a 5" BS, I have plenty of room inside the wheel well. Even where it's located in the pic above I have almost 1 1/2" between the inner fender and inner wheel. My best guess at the WMS to WMS with the wheels placed as about gives me about 54 1/2" - 54 5/8", which sounds okay but given some of the measurements other have used and then calculating out their overall width to the outside of the tires on both sides, it seems short.
I'm really trying to figure out what I can get away with "safely" without setting the wheels to far in. Trying to find a way to take measurements with a mock up have been difficult, so I'm hoping others have had similar problems and maybe solutions on the best way to go. Pictures of the space between the outer fender looking up as I posted would be VERY helpful. I need to retake with a ruler that can actually be READ.
thanks in advance for any wisdom people can throw my way!
