Old 05-27-2015, 08:22 AM
Track Junky's Avatar
Seems to me that if you get the oil hot enough your oil thermostat should open up and let oil into the cooler. Once the lines and cooler are filled then have the oil capacity in the pan that is required for said pan. No need to run the engine to check oil level. 6 quart pan = 6 quarts of oil in the pan with engine off.
Gaetano Cosentino
