  #28
Old 12-20-2015, 08:39 PM
bonecrrusher's Avatar
bonecrrusher bonecrrusher is offline
So I started off with the Vette sitting on the ground this morning - and well I got a lot done today.
I got the rear coilovers out, then disconnected the rear upper control arms.
I had to take out the drivers side long tube header to get access to the bolt holding the slave cylinder to the bell housing.
I then got the slave cylinder disconnected, the brake lines disconnected, and the wiring harness that runs down the trans tunnel disconnected.
I then setup the trans jack - zipped off the rear subframe bolts - and got started on the torque tube bolts.
I struggled with one of the torque tube bolts into the bell housing because that wire harness was in the way.
After getting that off - I got the torque tube out and the drive train dropped out of the way.
I plugged the brake lines with plugs from my Brembo kit - and a closet wire shelf end cap - saw that suggestion online -and it worked like a charm - no brake leaks here!
2005 LeMans Blue Corvette w/ T56 & Z51 & C6Z06 Brakes, Build Thread: https://lateral-g.net/forums/showthread.php4?t=27408
2005 GMC Sierra 2500HD - LLY - Allison
2014 Chevy SS - LS3 / 4 Doors
