Old 10-10-2006, 05:40 AM
avitet avitet is offline
well how much it will cost depends on. are you going to buy a kit or piece it togther can you do the work your self or have a shop do the work. but in general everyone was right the short block will be the most important part but rember the better heads and intake you use the less boost it will take to reach your goal and if you have e85 readily avabile you could look at nut running an inter cooler wihch brings up the fule system which is nearly as important as the shortblock.
