Old 02-01-2017, 05:45 AM
nicks67ca nicks67ca is offline
Default C6 Pedal 25835421
I'm curious to see if there is a need for a pedal stop on the GM 25835421 corvette pedal. I'm using the PSI harness with an LSA which requires the use the this pedal (67 Camaro application). It looks like there are some built in stops on the pedal it self but based on the alignment to the clutch and brake it will need to sit away from the firewall some. I plan on using a modified ironworks bracket to create a secure and flat mounting platform.
Also the pedal seams to have very little overall travel is this common in DBW set ups?
thanks Nick
