Old 12-02-2017, 12:45 PM
67_camaroRS's Avatar
67_camaroRS 67_camaroRS is offline
I tested the vacuum with a tester and got about 9 inches of Hg Vac on idle. Got about 17 inches on 2000 rpm. the length of the pedal was 12 inches and to the master cylinder rod it was 4 inches which makes the ratio to 3:1 i believe.The master cylinders reservoirs were identical in length but the rear one is smaller from the inside. I did BED bleed the master cylinder when it was new. What is the next step? Vacuum Pump? or?
1967 Camaro RS
1969 Camaro coupe
