Old 01-13-2018, 05:03 PM
Yelcamino's Avatar
Yelcamino Yelcamino is offline
Default Chevelle 2.0
Since Photobucket kinda messed up my original Chevelle 2.0 thread, I decided to just start fresh with a new one. So here goes Chevelle 2.0 again, AKA, The Blue Car.
The plan is to make this version a more dedicated track car along with some autox. The first step is to update the chassis and I decided to build my own (more or less) because my budget doesn't allow an aftermarket chassis.
This has been going on for some time so there will be an overload of pictures with or without comments just to get caught up.
As a side note, this is the first chassis I’ve built. You may see some things that don’t make sense to you or it may seem like I’m doing things the hard way, and I probably am! I’m learning as I go and ask for help when I need it.
This is the donor '66 chassis I started with:
00001 by Yelcamino, on Flickr
The first thing I did was to strip it down to the bare frame.
00006 by Yelcamino, on Flickr
Next I got it sandblasted.
00007 by Yelcamino, on Flickr
Then I sprayed some primer on the areas that I was going to keep.
00008 by Yelcamino, on Flickr
Once I got the frame mounted on the frame table, I installed all of the suspension from my car on to the new frame. That way I could locate the front and rear axle center lines. Once I cut the front and rear sections off the frame, I needed to know where to put the new stuff.
00009 by Yelcamino, on Flickr
00010 by Yelcamino, on Flickr
Speaking of new stuff, back when I worked at Ridetech, I bought a front clip from Scott Mock that uses C5 components.
00012 by Yelcamino, on Flickr
With the suspension mounted I was able to locate the front axle center line. To ensure I put the new spindles in the same place, I made a pair of stands that I could bolt to the hubs and table to keep things from moving around.
00013 by Yelcamino, on Flickr
00014 by Yelcamino, on Flickr
After I felt confident about the center line, I placed the new front clip on the frame to get an idea of where I needed to cut.
00015 by Yelcamino, on Flickr
Instead of cutting off too much, I chose to be a little more cautious. I cut the main cross member off…
00016 by Yelcamino, on Flickr
And then I followed that up with more precision cuts.
00017 by Yelcamino, on Flickr
Herb
1966 El Camino LS408/T56Magnum
1966 Chevelle 509/T56Magnum
1963 C10 454/4L80
PHR CHP CHP Youtube
The Following User Says Thank You to Yelcamino For This Useful Post:
camcojb (04-04-2018)
