Old 06-18-2020, 02:21 PM
Kwag Kwag is offline
Default It's been a while...
It's been a while.
I've got the car 99% of the way stripped and I'll be using chassis saver then monstaliner on the underside to stop rust and protect it in the future.
I've been using these scotch brite bristle discs that are insanely expensive but do a great job.
A couple questions for those who have been down this road...
1. I'm taking off the undercoating on the inner rear wheel well using a torch and scraper. This is a really nasty job. Anywhere else on the underside where I should look to remove this before coating with chassis saver and monstaliner?
2. I'm going to be running the mentioned paints up to the firewall but considered doing the firewall as well. Any input or thoughts from those who may have done this?
3. My front wheel wells are still on the car and in excellent condition. I'm thinking about removing them and coating them as well. Thoughts from those who may have done this?
4. Lastly I'm about to scuff and spray the 383. Any heads up on things I should double check are blocked off?
5. I have a 3.70 rear gear and I'd like to order a TKO600 kit. Any suggestions on best companies to order from. I have a quote from American Powertrain, are they reputable?
- What will drivability be like with a .64 overdrive?
Thank you for your help!
Thank you!
The Following User Says Thank You to Kwag For This Useful Post:
Roscoe03 (06-18-2020)
