Old 10-02-2021, 12:44 AM
srode1 srode1 is offline
I don't think your fans do anything at highway speed, I agree turning them off with a switch wouldn't change the temperature. You can do the math to confirm if you want. Your set up doesn't look bad to me for an electric fan set up, but you are blocking some of the radiator with the shroud. A pusher fan isn't going to help things, it will block more air, don't do it. Around town bigger diameter fans would help probably, maybe some on the highway too. Do you know what your A/F mixture runs in those conditions? Maybe you are running too lean?
The Following User Says Thank You to srode1 For This Useful Post:
dhutton (10-02-2021)
