Old 10-01-2022, 07:32 AM
rocketrod rocketrod is offline
Default Upgraded 1st gen subframe, Hydroboost, Baer, C5 Acc. drive
All items have been sold.
1st Gen Camaro subframe SOLD
  • Complete front subframe and suspension. Just add brakes of your choice, wheels and bolt it to your ride.
  • OEM subframe sandblasted and powder coated satin black
  • ATS 670 steering box with rag joint coupler
  • AFX Spindles
  • Fast ratio steering arms
  • SPC Stage II Upper and Lower Control arms
  • Varishock double adjustable front shocks
  • Helwig swaybar
  • Hotchkis 2' drop coil springs
  • S&P LS Swap brackets
  • Stainless steel brake lines
  • Replaced inner/outer tie rods
  • Hotchkis tie rod sleeves
C5 Corvette accessory drive - SOLD!!! Hydroboost and Master cylinder - SOLD!!!
  • Hydroboost base model purchased from Hydratech
  • Hydroboost has stainless steel slip cover
  • Baer Remaster, 1 1/8" bore, black (has about 1,000 miles on it)
  • Baer proportioning valve, mounting bracket and lines
  • I can include the stainless steel lines and fittings
Rod
1969 Camaro - LS2/4L70E
