Old 01-03-2007, 07:39 PM
Default 691 rwhp Procharged 406 for sale
Listing for a friend. I built this motor for him a couple years ago, and we had it apart for inspection last year when he started to re-do his car. Made 691 rwhp at Speed Merchant in San Jose.
factory 400 2-bolt block with partial fill
4340 steel 3.75" crank
6" H beam rods
Ross custom blower pistons
Speed Pro Plasma rings
Milodon 7 quart pan
Cloyes true roller chain
Comp hydraulic roller blower cam and lifters
AFR rev kit
Victor Jr. heads with Stage IV port by CFM Performance
Crower stainless 1.6 roller rockers
Holley SR intake and throttle body
75# injectors
MSD 85551 billet dist with GM melonized gear
MSD 8mm wires
D1SC Procharger with 11 and 14 psi pulleys
Procharger brackets, pulleys for water pump and ps
ps pump
Edelbrock Victor aluminum water pump
GM Performance cast aluminum valve covers
FAST EFI and harness
Complete throttle body to pan, including new FAST computer and harness. Have a good starting tune in the computer, may need minor tuning once installed in your car. He is selling to fund an LS2 swap over in this car. Probably less than 1000 miles on this engine. Does not smoke, runs 180 degrees in 100+ temps (literally).
$8500. FIRM including the $2000 FAST EFI system. plus freight.
