Old 07-05-2007, 10:40 PM
Dave95z28 Dave95z28 is offline
My Mez has over 10,000 miles on it. Make sure it is wired in properly with a good relay and it will run problem free for a long time. Advantages of running a Mez besides a few HP is that one you can run a much lower cost higher quality timing set than the LTX upgrade options and another is that you can run the pump while sitting at the track an keep the coolant circulating.
Dave
