Old 04-22-2005, 11:04 PM
Sandro's 1969 502 Camaro's Avatar
Sandro's 1969 502 Camaro Sandro's 1969 502 Camaro is offline
Originally Posted by GEORGE SANCHEZ
Just Wonderin On Your Smoothies What Sizes Did You Use I Loved That Look I Have Your Car As My Screen Saver .did You Use A Shortened Rearend ,or If It Was Stock What Offsets Did You Use ?
Tire And Wheel Combination Did You Use?
I Wish I Would Have Bought Them Please Help Me Out With The Info Thank You
I was running a 20x8.5 with 5 1/4" b/s and 285/30R20 tire. My rear end is a 12 bolt housing that was built to stock width, but I'm running big ford bearings (no c-clips). The leafs are globle west cat 5's dearcked about 2 1/4 inches. I think a total of just over 3.5" inches.
In the front a 18x8 with 5" b/s and 235/40R18. On the fornt I run 2" dropped spindles and QA1 adjustable coil overs. After installing the dropped spindles I had to run a 1/4" spacer for clearence between the tire and tie-rod end.
If your going to order rims I would just use this as a reference. I've probely let about 3 or 4 other people try my rims on their cars (all camaro's 68,69's mostly stock) and they never fit the same way on each car..
Old 04-24-2005, 01:14 PM
GEORGE SANCHEZ GEORGE SANCHEZ is offline
Default thanks
thanks for the info it will come in really handy
JUSTACOUPE
Old 04-30-2005, 08:24 PM
tndude tndude is offline
Default New Wheels
So Sandro, did your new wheels show up yet?
Show us that ride!!!!
Old 04-30-2005, 09:11 PM
Still waiting, probably be here May 30ish..
Old 05-03-2005, 05:13 PM
ViperBlue68's Avatar
ViperBlue68 ViperBlue68 is offline
Location: Yuba City, CA (about 1/2 hour North of Sacramento)
I had issues with my drop spindals as well I had a 18x8 with 5" b.s. and it rubbed the tie rod end... changed to the 4 & 1/2" b.s. and it fits fine...woulda never used the drop spindals in the first place had i known it....
J.T.
Old 05-04-2005, 12:38 AM
I felt the same way but at the time I had sent all my front bear set up back and exchanged it for the drop spindle set up.
My car sat to high without the spindles so I had to compromise. Now with the 20's in the front there is lots of room even with 5" b.s.
Old 05-31-2005, 12:05 PM
Do you have wheels yet?
Old 06-01-2005, 02:55 PM
groovyjay's Avatar
groovyjay groovyjay is offline
Sure looks great on the photo! Can't wait to see the new pics once you get the wheels mounted!
Old 06-12-2005, 09:15 AM
So far I only have the fronts, I recieved the rear wheels only to find out that they sent me the wrong offset. To be hounest, I've never dealt with a company that has made so many mistakes and done so little to correct them. Very unhappy......
Old 06-12-2005, 10:17 AM
jonny51 jonny51 is offline
Sorry to hear that Sandro,it seems like alot of people in the automotive aftermarket industry don't care about there customers.
