Closed Thread
Old 12-07-2004, 04:37 PM
Musclerodz's Avatar
I got one word, SICK!!!
Mike
Mike Redpath
Musclerodz & Customz
facebook page
Old 12-07-2004, 05:55 PM
c.schulz's Avatar
c.schulz c.schulz is offline
Default Power Tour
Originally Posted by camcojb
Should be ready to fire late January/early February. I have the hotels booked for Power Tour so it better be done by then.
Hey Jody need a co-pilot????? Please???
71 RS Pro-Touring thing.....will it ever be done?? Not with out a second mortgage! SOLD
  #13
Old 12-07-2004, 07:10 PM
Lateral-g Moderator
Default Car
AWESOME!!!! You will be styling on the Power Tour.
  #14
Old 12-07-2004, 07:48 PM
61Bubbletop's Avatar
61Bubbletop 61Bubbletop is offline
Lateral-g Moderator
Default Wow...
My goodness , Jody, you should just put that whole engine in a glass case!...Looks fantastic my friend, and that is about as much an understatement as there ever was!
  #15
Old 12-07-2004, 08:35 PM
hotwheels's Avatar
hotwheels hotwheels is offline
wow, that is pretty........mine is almost like that......i sprayed it with a can of aluminum paint from autozone......
1992 mustang gt twinturbo'd
1988 mustang gt bottlefed
2004 mach 1 resting in garage
1989 mustang coupe 4 cyl.
1980 mustang coupe 4 cyl.
MY MUSTANG ENTHUSIASTS SITE
Insanemustangs
  #16
Old 12-07-2004, 11:18 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Looks nice I think.
Ya' think??.... I know!! Very nice piece there Jody!! You scored bigtime!!
  #17
Old 12-07-2004, 11:26 PM
camcojb camcojb is online now
Thanks guys, I appreciate it!
  #18
Old 12-08-2004, 01:43 PM
Blown353 Blown353 is offline
Jody, what's the plan for linkage? Are you planning on a a rod end / link / bellcrank system to tie both TB's together and then using a single cable to work the bellcrank?
It's hard to tell in the photos but are the TB's feeding seperate plenums for each bank, or one common plenum? If it's a common plenum having the TB's slightly out of sync wouldn't be a big issue, but if they're each feeding a seperate plenum then I'd want them as sync'd as possible!
Looking good...
1969 Chevelle
  #19
Old 12-08-2004, 03:34 PM
Looking good...
I'll let you engineer it Troy! I'm going to try turning them so the throttle shafts are in line with each other horizontally and connecting the two shafts and using a single cable for throttle. They feed a common plenum thankfully!
  #20
Old 12-08-2004, 03:48 PM
Steve Chryssos's Avatar
In-FREAKIN-Sane!!
In-FREAKIN-Sane!!
In-FREAKIN-Sane!!
________________
Steve Chryssos
Ridetech.com
Closed Thread
