Old 07-06-2007, 11:28 AM
Stang's Bane Stang's Bane is offline
Originally Posted by DB Z28
6800 rpm
What camshaft did you go with??
Old 07-06-2007, 12:04 PM
DB Z28 DB Z28 is offline
Here,s the start of the list on whats inside
GM LS-7 GM Block
Callies Compstar rods and crankshalf
Ati balancer
Mahle Rings and Pistons
LS-7 heads reworked
11.1 CR
Modifed Rocker arms
GM performance LS-7 intake Modifed and ported
2 spacer intake
Pathera EFI system
Holley throttle body
PSi springs?
Comp Cams cam. 600 lift
Stock ls-7 dry sump pan with -12 fittings
Stewart water pump
Wagner pulleys and brackets Which makes them for Detroit Speed
Old 07-06-2007, 12:35 PM
GM LS-7 GM Block
Ati balancer
LS-7 heads reworked
Modifed Rocker arms
PSi springs?
Comp Cams cam, 615 lift ?
Throttlebody going to run two new ones and see whats the better of the two.
Stewart water pump
Cool,
I went with the Callies crank and rods too, very nice pieces. I assume HS did the rockers??
Very anxious to see the final numbers for this.
Old 07-16-2007, 05:45 PM
1984 camaro's Avatar
1984 camaro 1984 camaro is offline
Default ls7
Hey dale that looks good
R D
Old 07-17-2007, 03:48 AM
deuce_454's Avatar
what is the point of ditching the GM LS-7 titanium rods in favour of a set of callies???
Jake: Hit it.
Old 07-17-2007, 04:10 AM
Their was rods and pistons failed in the wrist pin area. from what I was told.when you start pushing it over 625 hp.Mahle pistons guys also said their was problems. As for going to a Callies crank or stock crank . On a stock crank you would have to drill out the crank so much to add weights it would make it weaker for the heaver rods.
Old 07-30-2007, 07:42 AM
Any numbers yet??
Old 07-30-2007, 09:45 AM
waiting for a differant cam and more intake work
Old 08-28-2007, 05:14 PM
Ran it today it was Hot and Muggy
It pulled 711.7hp at 7100 rpm
Max torq 610@5521rpm on pump gas 93 oct At 6628 rpm at was at 700hp
1 7/8 headers tri y with 3in exhaust with h balance pipe no open headers
sounds realy nice will have more pictures later
We hit the 100 + hp per liter on pump gas
Old 08-29-2007, 01:33 AM
tyoneal's Avatar
tyoneal tyoneal is offline
Do you have any Dyno Charts you can post?
What type of Coin does it take to get into something like this??
Very Cool Engine,
Thanks,
Ty O'Neal
