Old 06-08-2005, 08:53 AM
T Bell T Bell is offline
Default rhino lining
Anybody ever coat the bottom of their car with this stuff? I'm thinking of doing the Cutlass while it is off the frame. Any idea of how much it would cost?
1972 Nova 355, 4 spd, rusty but something to drive.
1972 Pro-touring Cutlass S in the works....still
Old 06-08-2005, 08:59 AM
Ummgawa's Avatar
Ummgawa Ummgawa is offline
One Million Dollars.....
Jim
Old 06-08-2005, 09:41 AM
TravisB TravisB is offline
I have never done it myself but I know the Sick Fish that Troy built was coated on the bottom...very clean & sanitary
Cost????????
Kenny Davis Hot Rods
Old 06-08-2005, 10:20 AM
96z28ss's Avatar
96z28ss 96z28ss is offline
I think the bottom of sick fish was just powder coated not rhino lined.
Old 06-08-2005, 10:31 AM
I will look this weekend it should be at Indy! I was under the impression the bottom of the car and the inside of the car...floor, firewall,rear seat delete area was all coated, it may not be rhino liner but it is some sort of textered coating!
Here a pic of the bottom of the 56 in there shop now this same stuff is on the sick fish!
Old 06-08-2005, 12:35 PM
I thought they coated over the powdercoating on the underside?
Old 06-08-2005, 12:53 PM
69MyWay's Avatar
69MyWay 69MyWay is offline
I coated inside and out of my 69 Vette pan and my 69 Camaro with truck bed liner. I thinned it down a bit to avoid excess build up where it was not needed. I shot the inner firewall and the ceiling, inside the trunk and backside of the quarter panels.
Cost?
You can get the gun for about $20 at most paint supply stores (body shultz gun). There are different types of "rhino" liner (epoxy, urothane, etc) and brands.
It usually runs around $100 or so for a two quart kit. You want to get the two part kind as it bonds better and should last much longer.
Old 06-08-2005, 01:31 PM
69rs's Avatar
69rs 69rs is offline
What would be the pro's/con's of using Rhino as opposed to any other undercoating/treatment?
Old 06-08-2005, 01:41 PM
from what i've read, it's pretty tough and it seals out water and air completely. Meaning no rust. It probably has some heat & sound deadening effects as well.
Old 06-08-2005, 02:12 PM
69MyWay's Avatar
