Old 11-08-2007, 03:00 PM
preston preston is offline
Wow some very very impressive home built cars. Amazing.
But garages are for wimps - I'm looking for carport built cars !
Old 11-08-2007, 06:46 PM
joe440's Avatar
joe440 joe440 is offline
Default All in the garage
Old 11-09-2007, 12:41 AM
deuce_454's Avatar
on the 32 i have done everything... and still need to do everything it seems.. but ill spray it my self as well
and my 65 is only mud, paint and assembly away from completion, but i had a pro replace the quarters on that one... other than that, its completely homegrown (mustangsplus track suspension, 5.0, t-5 restomod..)
Jake: Hit it.
Old 11-09-2007, 02:21 AM
redfire69's Avatar
Those cinder blocks make great jack stands (I'm guilty of cinder blocks, bricks, and even a good landscape rock as a wheel chock in a pinch)
But really, that's a pretty wild tube chassis stang!
Old 11-09-2007, 04:53 AM
G-Body's Avatar
G-Body G-Body is offline
Heres some more progress pics of the hot rod comming along pretty well ready to come back off the frame soon !
Old 11-09-2007, 05:35 AM
DHARROD's Avatar
DHARROD DHARROD is offline
1969 Chevelle (this one done almost to org match #). Had to use a buddy's garage. Did everything except assemble the engine (Chassis, body, paint, interior, glass)
Old 11-09-2007, 05:46 AM
DHARROD's Avatar
After the above 69 I took my matching number chevelle (restored in 1990) and decided to go through it. I now have my own garage. Doing everything except the engine which was built by a engine builder. Some more pictures under Member's section: https://lateral-g.net/members/harrod/
Old 11-09-2007, 11:34 AM
zyal8r zyal8r is offline
Did everything but interior and engine machine work in a buddy of mines garage that his dad had been using as a wood shop. Here are a couple of pics.
Old 11-10-2007, 06:09 PM
Bandit Ls-1 Bandit Ls-1 is offline
Its kool to see people actually building their own stuff rather than writing checks. Im also building my trans am at home in my 2 car garage bothering my neighbors with the noise, i doing everything from mechanical to body and from electrical to metal fab. id build my own roll cage but it has to be approved to run it at the track so ill have someone build it
1979 Trans-Am Ls1 project
1972 Chevelle 454
Old 11-10-2007, 10:18 PM
surreyboy
Guest
Posts: n/a
tried "writing cheques" and ended up with overpriced shoddy work.
