Old 11-21-2007, 04:59 PM
zcrz zcrz is offline
Default When is yours vibrating?
I have a 69 witha 350 and TKO 600.....and i have a slight vibration at cruising speeds, but I havent checked it out really.
Old 11-21-2007, 07:06 PM
wiedemab's Avatar
wiedemab wiedemab is offline
Default A few of my experiences
Just a few thoughts from me.
Have you guys checked the bellhousing runout? If it is out of spec - it can cause issues. I had to buy offset dowels for my block to get it within spec.
http://www.priveye.com/images/lakewood.htm
I had a vibration in my Mustang after getting it back together. Here is the thought process I went through.
Does it vibrate when only when moving? - If so, lean towards wheel balance, driveshaft, bent axle etc.
Does it vibrate when rev'ed in neutral - this isolates it to the engine and transmission.
Does it vibrate when you have the clutch released? - this eliminates anything internal to the tranny, as it isn't spinning then. It could still be bellhousing misalignment causing wearing/pressure on the pilot bushing/bearing.
Does it vibrate with the accessory belts removed? If so, you've isolated it to the rotating assembly of the engine, which in my case is where I ended up.
My next step was to pull the transmission, clutch and pressure plate and run the engine with just the flywheel. At this point, my vibration basically went away. My findings were the (unnamed brand new) pressure plate was out of balance. Unfortunately for me - it had already damaged my main bearings
I know that was a long story, hopefully it gives you some useful information. I had driven my car less than 100 miles trying to diagnose the problem - so caution - depending on the magnitude of the vibration - it can do some serious damage.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 11-21-2007, 08:29 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
I have the same issue right around 65mph. I think it needs the drive line balanced.
Curtis
Old 11-22-2007, 05:56 AM
Clockwork's Avatar
Clockwork Clockwork is offline
I'm finding out that running it with no yoke is not a good idea, which is what I was afraid of.
I have been fighting this for a while and I think there's 2 vibe problems. There's a slight vibe at about 2600 rpm coasting in neutral, and one at about 60 mph and up which concerns me more.
I have done pinion angles, new rear end, run with no wheels on, driveshaft balance a couple times etc...
I'm thinking of checking the runout and flywheel/pp balance next.
Dean
